CF Card
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
RickC
Car: QX56
Hello, I have a 2009 QX56. I have set up a CF card with a directory structure containing sub directories so I can group music together. When I put it in the car it ignores all of my catergories and shows only each individual directory. For example, I have a directory called easy listening, under that I have several sub directories for various artists. The same for pop, rock, or whatever. When I pop it in the car the directory structure is gone and it only shows each artist directory. Help!!
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
[QUOTE=RickC]Hello, I have a 2009 QX56. I have set up a CF card with a directory structure containing sub directories so I can group music together. When I put it in the car it ignores all of my catergories and shows only each individual directory. For example, I have a directory called easy listening, under that I have several sub directories for various artists. The same for pop, rock, or whatever. When I pop it in the car the directory structure is gone and it only shows each artist directory. Help!![/QUOTE
I have the same set up on my '08 Armada. Your best bet is to use a CF card that is 2GB (I know that seems small). Do not make any categories or directories. It may not be as organized, but at least it all works then.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
