It's not only the diameter of the wheel that determine if it would fit or not. If it works with 19's, it'll work with 20's. What you would need to start looking at would be the back spacing on the wheel. If there is not enough back spacing, the spokes may hit the calipers and cause all sorts of trouble. If your wheel does not have enough backspacing, a spacer could do the trick. For instance, on my brothers Lexus, the wheels come super close the caliper, but they fit with less than a centimeter of clearance. (Click the pic for full size if you can''t tell how close the spokes are to the caliper in that resolution.)vi3t89 wrote:so it wud fit if someone had 20's to?
damn! that wheel must be hell to keep cleanMr. Music wrote:It's not only the diameter of the wheel that determine if it would fit or not. If it works with 19's, it'll work with 20's. What you would need to start looking at would be the back spacing on the wheel. If there is not enough back spacing, the spokes may hit the calipers and cause all sorts of trouble. If your wheel does not have enough backspacing, a spacer could do the trick. For instance, on my brothers Lexus, the wheels come super close the caliper, but they fit with less than a centimeter of clearance. (Click the pic for full size if you can''t tell how close the spokes are to the caliper in that resolution.)
That does not help either you need to check the clearance between the back of the spoke to the caliper.EzeebMOS3 wrote:I have 18x8.5 wheels. What is the best product for me? I want ceramic pads with slotted rotors
that is a gorgeous pictureMr. Music wrote:It's not only the diameter of the wheel that determine if it would fit or not. If it works with 19's, it'll work with 20's. What you would need to start looking at would be the back spacing on the wheel. If there is not enough back spacing, the spokes may hit the calipers and cause all sorts of trouble. If your wheel does not have enough backspacing, a spacer could do the trick. For instance, on my brothers Lexus, the wheels come super close the caliper, but they fit with less than a centimeter of clearance. (Click the pic for full size if you can''t tell how close the spokes are to the caliper in that resolution.)
LOL, yeah, it is a pain in the butt to keep clean. I had to help my brother clean the car before the photo shoot... and yeah, it took a few hours.mcheddadi wrote:
Makes me wish it was my car. Funny enough, that is pretty much the only picture my brother liked from the entire photo shoot, lol.How about some slotted or cross drilled rotors and brake pads for the new altimas, racingline?Racingline wrote:th
