504 350z wrote:i have a 2007 stick 350z, what difference does changing the gears make? will it effect mpg or top end? what gears come stock? pro's and con's?
Short answer, stock is 3.5. These gears will shorten up each gear by 10%. You will get to the sweet spot of the rpm range alot faster and it will be a noticeable difference.
Kinda like the old school muscle cars...they all went to 4.11 gears for harder acceleration.
You lose around 6mph off the top end. No real noticable gas mileage diff.
Hope that helps.
