Centerforce clutch
JICdrifter
so i heard u can use the KA clutch with the CA. Can u use a Centerforce dual friction clutch on the CA? i dunno if its different than the standard clutch. also does anyone have any expirience with centerforce? good or bad?? thanx
aaronsnocker1
Car: 93 240sx
I have had my centerforce dual friction clutch for about a year now and I am very pleased with how it has performed. I usually bang through all the gears and like to kick the clutch to get the *** end to swing. The only problem I am having is with either the throw out bearing or more likely the slave cylinder. Other than that great buy.
Trppen37
Car: CA18DET
I have used the centerforce dual friction on my kae and I plan to use it also in my CA.. i think after doing researching that the Centerforce Clutch can be used on the CA but I dont think the pressure plate can. In theory is it possible to use the KAE Clutch and use the CA Pressure Plate?? I have an extra Unsprung ACT 4 Puck Clutch I want to try out on the CA..
