center main bearing question
turner
Car: nissan pickup 1993 v6 4x4 VG30E
So the Napa replaced center main bearing rubber boot has failed. Is there anything crucial but not obvious to get on the replacing of the bearing and rear pinion seal?
PapaSmurf2k3
Site Admin
I can't think of anything. Maybe check any u-joints while you're in there.
newmexican
Car: 1986.5 d21 4x4
Make sure you mark your driveline so it goes back together the exact same way. Put a line long ways down both shafts for reference. I just did mine and i didnt even need a press. I just smacked it off with a punch and used a 2x4 with a whole drilled in it to install new one. Good luck
