BaliLover »
https://forums.nicoclub.com/balilover-u6785.html
Wed Jul 06, 2005 5:40 pm
I remember around 10 years ago every hood that came into my shop was getting 15" 30 spoke Cragar knockoffs and skinny *** Vouge Tyres.
They are a PAIN to put on and get off, even with the lead hammer and wrench they come with to install them. As SRsmith said, they have an adapter that bolts to your hub as seen in the picture. THey are color coded for left and right hand side, and the threads, as SR said, are left and right hand accordingly.
You are supposed to check them every few hundred miles and make sure they are tight (put the included wrench on and hit it a few more times). If you put left on the right and vice versa, they WILL fall off going down the road. I've seen it happen.
The one REALLY bad thing about them, if you don't use some type of anti-seize compound on the threads, theres a decent chance the center nut will freze on there, and nothing short of a stick of dynamyte is going to free it up. I saw one guy use a 6 foot cheater bar, impact gun, sledge hammers, and still couldn't get his off. Ended up having to heat the nut till it was glowing red with a torch before it would budge.
