So I've been slack this wk by not posting updates but the bearing has been replaced and required a few hrs. to complete. My 14 year old son did a good bit of the work to gain some exp.
Pics of the old bearing, we peeled away the old rubber to aid in removing the bearing.
My 10 year old daughter was the inspector and photographer.
Pic of the new bearing.
The old bearing is not pressed on but a vise, hammer and brass punch are recommended to tap the shaft apart. Don't do what this guy and hammer the dust cover for the bearing.I punched a hole through it requiring a replacement and a unnecessary trip. I should have known better but you don't have much metal surface to hit and the rubber absorbs too much of the blow. Next one I do I will remove all the old rubber and use the metal the rubber was bonded to.
This is a pic. of the separated shaft after the bearing was removed. There is a 1 1/16th inch nut and a copper washer that have to be removed before separating the shaft.
The new bearing came with a 24 mm nut and copper washer but I chose to use the original nut with the new copper washer.
Be sure to keep the splines and shaft that goes into the trans. clean and protected from scratching and debris.
A thin film of synthetic oil was used to aid in assembly.
Dust cover in place, bearing, then copper washer then the nut and that concludes the reassembly. CAUTION I used chalk as recommended to mark the trans. and ea. piece of the shafts to be sure they were all lined up when reinstalled and it was getting rubbed off from working on it. I had some white touch up paint that I used instead and worked much better.
In all not a terrible driveway project but the extra set of hands and patience were needed. To get the shaft to separate to remove the bearing required more force than I expected. The end result the noise is gone and a slight shudder I had when taking off is also gone. It feels like a new truck now.
