cdmuile »
https://forums.nicoclub.com/cdmuile-u84276.html
Thu Mar 20, 2008 3:09 pm
The whole design of that center consul is just plain goofy. Our current Azera as well as the previous car had a two part storage area. Squeeze the front mounted latch, lift and the top compartment opened. Squeeze the bottom latch, lift and the bottom opened. No rocket science stuff there. In the Rogue, unless you carefully read the manual, you wouldn't have a clue that there are actually two compartments. The top box that has to be lifted out to access the bottom one, is hard unlined plastic and can be a pain to lift out. I used the power source in the lower area to power my backup sensor. 'The cord was way too long so to avoid splicing I carefully wrapped up the excess cord and held it together with tape. Then, I couldn't get the top box back in. A lot of unnecessary fooling around because of a poorly designed consul.
