No reason to get a used one thats also at best 13 years oldjamesmost wrote:go to a good interior shop, they should be able to recover better then new for < $50
You have to take the back cover off the seat.Aussie Q45a wrote:Has ne1 figured out how to get that arm rest off the seat? I'd like to get mine recovered also and thought it might be a bit cheaper if I took the arm rest off myself.Greg
EDIT: Lower side bolsters must be removed , OR the seatback must be tilted forward, prior to Sectiions#1/#2.anlasak wrote:You have to take the back cover off the seat.
Remove section #1, and then section #2 in the following diagram.
