It may be a #10 from the factory but the reason they fall out is because the #10 is likely stripped. I had to up the size and switch to a sheet metal screw (bigger threads) to get it to stay in.gluys wrote:My center console was the same way!!! The dang thing squeeked everytime I took a turn! But I took a screw up to homedepot and found out that you can get a screw that works perfect for the center console for a buck (3 metal self drilling screws). But it is a #10 X 3/4" pan head phillips self drilling screw. It is under the metal screws and made by crown bolt. Hopefully this helps anyone that has access to a home depot!!!
-Gluys
