Center console removal
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
anyone have a link to a thread or any info on removing the center console? Clock is disconnected plus i want to swap my gold one in there and the 6 disc changer doesn't transmit to the speakers on the new body. Gotta get under there and check it out. Whoever had this one put a decent alpine system in it. I want to hear it before i think about tearing it out.
Q451990
No pictures, but here's a step by step Brian got from another thread and posted in 2003.
From a past thread:Instrument Cluster Replacement Procedure:
Fully Extend Steering Wheel
Fully Lower Steering Wheel
Place Gear Shifter in "D"
Remove Shifter Cover Plate (gently pry up back of plate located closest to you, and disconnect wire harnesses for power windows from plate) and set aside
Remove two screws at rear of shifter cover plate area
Remove two screws securing metal bar and ashtray assembly
Remove metal bar
Remove ashtray assembly
Remove two screws behind ashtray assembly location
Remove Forward Steering Wheel Housing Cover (closest to you-4 screws), housing is in two pieces upper and lower
Remove Rear Steering Wheel Housing Cover (4 screws, 3 outside and 1 inside lower half)
Gently pull housing (section covering A/C Controller and Car Stereo) away from dashboard (pull in down and out motion)
Disconnect wiring harness connectors
Gently Remove Left lower Dash plate (section around cruise control switch, mirror control, etc)
Remove 7 exposed screws from dashboard cover (5 lower, 2 upper)
Pull Outer Dash Housing (pry gently, side to side) and disconnect wiring harness connectors
Remove Outer Dash Housing
Remove 4 screws from Dash Display
Pull Dash Display
Invert Dash Display and remove the two screw in socket and bulb assemblies
Reverse procedure to reassemble
I will add, there are two large bolts that hold the steering column up to the body of the car under the cluster. Remove these so that the column drops down a bit. This will give you room to get the trim off without gouging it in the usual spot next to the ignition switch.
EDIT: Just noticed this was posted for a 1998 model, but the steps seem to be the same. Remember that you need to remove the lower cover that's around the brake and hood release handles... you'll be amazed how heavy that stuff it. These cars were really built!
Heath
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
A couple of pictures that might help supplement what Heath shared:
http://www.carstereohelp.com/s...o.htm
