center bearing question, driveshaft
gloucester Q
Car: 90 Q
i have a 93q, built 11/92. i called up everything infiniti to order a center bearing and whatever else i would need and was told that this is not a separate part, the d-shaft comes with it and as one. is this right? i was under the impression it was a separate part? at any rate, i'm 1/2 way through the driveshaft r&r. got the mtr mnts and transmission mnts replaced 2 weeks ago. smooth as butter at idle, pretty smooth at hwy speeds, and a noticeable improvement all around, but still a lingering vibration between 35 and 45 mph. looking forward to knocking it off the list and hopefully it'll be smooth sailing from there. any clue what i need or don't need to address the center bearing? thanks. randy
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I have the part number for the carrier bearing
37521-6P025
See what Joe can do with that.
gloucester Q
Car: 90 Q
wow. joe confirmed it--93 and earlier can not replace just the center bearing, it's the whole driveshaft assy or bust. wes-the number you have is the correct number for a center bearing kit ($104 fyi for anyone interested) but it is specifically for 94-96. randy
DAEDALUS
Car: 1990 Infiniti Q45
How much did he quote you for the driveshaft assy?
gloucester Q
Car: 90 Q
shoot! i totally forgot to ask. i asked a month or so ago when i started looking into this and it was in the 500s to the best of my memory.
elwesso
2007 BMW M Coupe
The bearing is pressed on the same way as it is on the 94, so i dont see why you couldnt replace it???
JedCoop
Car: 94 Q45t w/TCS, 92 Q45 w/TCS, 91 Q45 touring (RIP)
gloucester Q wrote:wow. joe confirmed it--93 and earlier can not replace just the center bearing, it's the whole driveshaft assy or bust. wes-the number you have is the correct number for a center bearing kit ($104 fyi for anyone interested) but it is specifically for 94-96. randy
I had thought that 90-96 driveshafts were interchangable. Only thing different on a driveshaft is whether or not you have TCS. Guess I am wrong.
elwesso
2007 BMW M Coupe
That doesnt even matter.. I put a TCS driveshaft on my non TCS Q
Q451990
The 90-93(?) driveshaft had a smaller center bearing... they were upgraded later. When you order a new replacement shaft you also have to replace the center carrier bracket. So the new driveshaft sold for the entire series was originally the 94-96 design...
Heath
elwesso
2007 BMW M Coupe
Good information heath!! Thanks for clearing that up!
SFBayQ45
Car: cars
DAEDALUS wrote:How much did he quote you for the driveshaft assy?
$547 + S/H...I took the bite, so I still remember the scar!
DAEDALUS
Good to know. I have the driveshaft off the car right now and I'm weighing my options. I'll probably just bolt it back up and wait for the bearing to start going out, then look for an aftermarket equivalent. I've already booked about $3k for deferred long-term items for the summer. Thanks for the info.
JedCoop
elwesso wrote:That doesnt even matter.. I put a TCS driveshaft on my non TCS Q
But you might not be able to put a non-TCS driveshaft on a TCS... and expect the TCS to keep working. I bet the TCS driveshaft has some magnetic pickups on it like ABS does on the wheels.
gloucester Q
Car: 90 Q
thanks guys. that makes sense and reconciles the different things i was hearing. going to see what i can do about loosening up those u joints next week and if not, i'll take the new d-shaft plunge.
Q45tech
TCS or plain: all done on Diff output [dual pickups] [TCS] or single input pickup [plain]-------thus the difference in drive shaft lengths.
squeefoo
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
gloucester Q wrote: i called up everything infiniti to order a center bearing and whatever else i would need and was told that this is not a separate part, the d-shaft comes with it and as one.
This from TexasOil some time in the last year:"Replacement center supports (bearing included) for The Q45 (and all other Nissan,volve, etc cars are available at low cost from PowerTrainIndustries.comQ45 part # is 1280-70"
I saved this just in case... Hope this helps.
1bluestraveler
Car: hunting fishing blues golf
Gloucester, I replaced the driveshaft in my '91, with a beefier one from a '94, from a yard for $50, if that center bearing goes bad, I can always buy a new bearing for $100, as mentioned earlier in the thread. but seeing as it is a stonger componant, it could last quite a while. Just a thought, it could save you a few hundred bucks from buying new.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Hey I have been doing some re-reading of Glouster Q's posts (the previous owner of my car).
I want to know is the 1994-1996 Q45 driveshaft pretty much bulliet proof besides the center bearing and one more part?
Also I read about some people rebalncing the drive shaft as well.
But I want to know because I found a sweet deal, and I am all about the best of the best of the best.
