center bearing mount torque specs for 240sx?
Ca_laurier
ok, i have been trying to find the proper bolts to use for my center bearing mount (aka drive shaft support). now there are 2 bolts on the 240sx and nissan said either they can order them from japan and it will take a few weeks or if i can find out the length and thread pitch they probably have some in stock.
this is what i came up with from the fsm
http://www.vosko.net/media/fsm/PD.pdf
its on page 5
32-38 (3.3-3.9,24-28)N-M (kg-m,ft-lb)
now these are just the torqing spec's
Silvia007
Car: 93 Nissan 240SX SE Fastback
Yep, those are just torque specs. I doubt they can find that info for you or you can find it yourself. They are the same bolts that you use on your transmission mounts, the bolts that bolt the mount to the chasis.
Ca_laurier
k sweet, i will head back to nissan and see if they have any of them.
thanks
180fan
Car: 89 fastback
next time please don't put "need help please"
