Center bearing issue
sr20671
Car: 89 nissan 240sx with a(n) ka24e engine Nismo r4 cam, injen intake, stage3 head obx headers Megan exhaust. Welded differential chrome polished valvecover
Here's the prob. With my center bearing... When I drive the car it would vibrate and shake..... So I put the car on the lift and checked the driveshaft when I shoot it and turned it, it would freely move around in the housing, so when I inspected the bearing it was cracked. Now I'm wondering how easy it is to remove the propeller shaft cause it's a b**** if you don't have an impact gun or a strong a** friend to hold the shaft.... Input please......
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Use some Dextron Automatic Transmission Fluid with Acetone in a 1:1 mix to loosen up the bolts.
comatoseculture
Car: 1990 240SX coupe. Currently running on Megasquirt.
To remove the driveshaft? no impact is needed, but how do you have access to a lift and not an impact gun?
Two 14 mm wrenchs is what I used.
