I wasn't trying to say that CDMA and GSM have anything to do with the bluetooth - I was moreso trying to elude the fact that the same phone on a CDMA network and a GSM network could be very different - such as the Razr or some blackberries. I was referencing the fact that even though sprint and verizon use the same style network, the phone could be different on each network.C-Kwik wrote:Bluetooth has nothing to do with CDMA or GSM. In theory, Bluetooth devics should all work similarly in terms of pairing. How they use the pairing is where some differences can be found. Best to test with other bluetooth headsets. If you haven't successfully used another phone with the G's bluetooth, then try that as well to make sure its not a problem with the G's bluetooth itself.
