Neejay wrote:Anyone here ever flashed or flexed their phone? Im thinking about doing it, but I have no idea what to expect after its done. I know its supposed to fix some bugs and possibly upgrade the phone, but the cons were something like making some menus/features disabled and slightly different menu icons.
I wish I could get some screen shots or something.
BTW, I am not sure what you mean by "flexing" a phone. I have never heard of this term!
"Flashing" means writing or updating the firmware (i.e., the software) inside the phone. This is done by [re]writing the programs into the "flash memory" in the phone - usually through the serial port in the bottom. Hence, "flashing" has become a verb!
As an aside, flash memory is used rather than random access memory (or RAM) since it retains its memory contents in the event of power loss (like when you replace the battery or turn the phone off, etc.)
The process of flashing is not generally a problem per se. You would do it to get the latest rev of the phone firmware, for example to add a new feature or to fix a bug of some sort. Recently, my LG VX4500 handset that I use, developed a problem and it needed the latest firmware loaded to fix it. The Verizon store rep did it for me in about 20 minutes.
Note that updating such firmware often means that some things in the phone change visible to you ... depending on the amount of difference between what you currently have in the phone and the later software. So, yeah, some menus may be different, some icons may be different, some features may work differently, etc., etc., etc. So, whether you should flash a phone or not depends on why you want/need to do it.
By the way, you will (very likely) erase all of your own stored info (like phone numbers in directories and the like), so you should either write it all down somewhere or use appropriate phone interface software (if you have it - like the programs from Smith Micro and others!) to record all your personal info.
Hope this answered what you were asking about. If not, please ask again!
Z
