robo_geek »
https://forums.nicoclub.com/robo-geek-u75923.html
Sun Mar 15, 2009 7:08 pm
If your EGR is stuck open, you're going to be idling pretty rough, most likely. if it's stuck closed, that will mostly affect emissions.
If you have a vacuum leak at idle, that's also going to mess up idle smoothness. If its a pretty good leak, it could cause an overall lean condition which would hurt performance.
In general, there are a couple of things that could be happening....if there is an intake leak it may make one or more cylinders run lean, causing some misfiring. Also, if your EGR ports are blocked up in the intake manifold, some cylinders are going to run lean.
I would try to track down any vacuum leaks, clean out the EGR ports in the intake manifold, and make sure your charcoal cannister is working right.
