CEL on since ive owned the car
jmhalder
Car: base model 95 S14, steeliez, boosted on the T25, going to HY-35, and 650's/N60/walbro/bikirom to han
alright, before i get flamed, ive searched, and no significant info is out there.
Since ive owned my 95 5spd 240, ive had a check engine light on, a buddy of mine just used his code scanner at his dads shop to tell me what it is, a detonation code (34 from my consult)... said it was probably the knock sensor. that was about 10-12 months ago, its still on, since ive done a 248/248 swap... and thats about it. just wondering, is WILL affect my ign. timing right like a limp mode? and will it make a noticable power difference by actually replacing the knock sensor? and this will effect my MPG right, considering it wont really do a complete burn if its too retarded.
(sorry im asking like 20 questions in one post)
fallen180sx
Car: 90 Sil80
if it was yur knock sensor you would be in limp mode.. causing your car to run like ****. Get more professional opinions, and is your car doing anything unusual while driving?
jmhalder
well, theres dozens of things about my car that are "unusual" but it runs pretty normally, i think my ignition timing is snafu... cause with the tps disconnected idle rises from about 1100 to 1880 and moves from 10btdc to 40btdc which are both wrong... unfortunatly i already got the most professional opinion im gonna get, and thats to replace the knock sensor.
fallen180sx
Car: 90 Sil80
then replace it if you feel like you should.. it also sounds like timing too.. wish i could be more help.
jmhalder
actually, thanks i appreciate it. this forum has been alot of help to me, i turned the timing back, consult is still reading ~30 btdc, and the timing light is off a little... but when i turned it back, the new idle without the tps is about 1400 rpm, still way off but better... so im taking a look at it tonight...
jmhalder
dear lord, after i found that idle screw i had to turn it WAY down... got it timed perfectly, but in the same respect i had to break something. i broke the top bolt on the distributor (one of the two you have to loosen to change timing) crappy nissan bolts...
