CEL lights up only while in gear with clutch engaged... wtf?
Tsukiko
Car: 1990 240sx fastback KA24E
and my computer is still throwing a VSS code. i replaced the vss sensor, and the overdrive switch, and i thought the overdrive switch got it. guess not. the CEL came on right in the middle of the smog test. AAAAAAGGHH!
anyone know why the CEL is turning on? its only when my foot is off the clutch in gear. when i go to shift or stop at a light it turns off.
leper421
Car: Current: 2011 370z
Previous: 2003 350z, 1991 240sx
Tsukiko
im glad you think im that much of a noob.
seriously. did you even read my post?
tRQmnsTR
Car: 1971 Datsun 510, 1989 Toyota Supra
1993 Nissan D21
Did you check the circuit before you bought the VSS?? or did you just throw parts at your car??
Tsukiko
i checked the wires and connections visually.
at the moment i dont have the proper electrical testing equipment.
i know, i know. go get one, use it.
i hate multi-meters. and wiring ****e.
