CEL light...
aukword1
Car: 04' g35, 04' rx8
i made a mistake...I cleaned my throttle body and forgot to plug the throttle body back in before i started the car...seconds after the car being on i realized what i did, turned it off and plugged it back in...now the CEL light wont go away, i did some research but all i came up with was that if you forget to plug the MAF and turn the car back on, it should go away after about 100 miles....well i drove my car about that and it still hasnt gone away...anyone have any ideas?
TDS
Car: 2008 G35
Have you tried reseting the ECU?
joe603
Car: 2014 Durango R/T
check the G-series FAQ in my sig for the reset procedures. It should clear it....
aukword1
yeah i did reset the ecu several times...still no luck..even tried it by d/c the battery...still no luck
aukword1
i also heard i might need to replace the throttle position sensor...would what i did damage that?....i just tried to reset the ECU again...still no luck, also my car now idles at about 1k rpms...as opposed to the 500-600 idle...kinda odd...
Tampa G35 Sedan 6MT
Car: 2006 Infiniti G35 Sedan 6MT Black w/ Premium & Areo Pkg
1989 Jeep Cherokee 4X4 Lifted and Old School!
go to an advanced auto parts or autozone and let them put the computer thing on it. It will tell you what it is and then you can clear it from the machine!
The best part is its FREE
DJ
aukword1
i will try that tomorrow...but doesn't that just clear it and not really fix the problem? if there was something wrong i'd like to fix it...
snwbrdr435
Car: 85 VW Westfalia, CBR F4i, SV650s, 1988 Honda Hawk(race)
How long did you disconnect the battery for? Maybe you reconnected it to soon.
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
Try doing the rest of the reset procedures.
Accelerator Pedal Release Position Learning
Idle Air Volume Learning (Throttle Position Learning)
After you do those, then do the ECU reset and see if all is well. Should take about 5-7 mins for all 3.
aukword1
okay i'll do it later today and see what happens
Tampa G35 Sedan 6MT
aukword1 wrote:i will try that tomorrow...but doesn't that just clear it and not really fix the problem? if there was something wrong i'd like to fix it...
The computer will tell you what the problem is! and then if it is something stupid erase the code. If the problem continues the light will come back on and then you need to worry.
IF you were messing with things under the hood that could cause it to go off and then if you fixed the issue the light would still stay on!
Erase<drive<worry about if it comes back!
DJ
telcoman
aukword1 wrote:i made a mistake...I cleaned my throttle body and forgot to plug the throttle body back in before i started the car...seconds after the car being on i realized what i did, turned it off and plugged it back in...now the CEL light wont go away, i did some research but all i came up with was that if you forget to plug the MAF and turn the car back on, it should go away after about 100 miles....well i drove my car about that and it still hasnt gone away...anyone have any ideas?
aukword1
I had a similar issue the last time I replaced my air filter. I started the car and forgot to plug the sensor back in. The CEL light came on. I spoke to the service department at the dealer & they told me it would go out by itself within a few hundred miles. It did after around 100mi. If nothing is wrong each time you start your car the ECU runs a series of tests. If it continues to pass all tests it will turn the CEL light off. Thats what they told me. If yours fails to go off you may still have a problem?
Telcoman
aukword1
yea thats what i heard...i'll try the reset procedures and the free test at auto zone, if all else fails...i'll do some more research...thanks guys for the posts..appreciate it..
BrandAidDesignG35
Car: 04 Infiniti G35 Sedan
I had a light on after I changed exhausts... it's now gone, but I changed my plugs since,... if you purchased used, you should change your plugs right away anyhow.
Try sentient's advice, reset all and then report back, or get autozone to clear em' but... they'll likely come back without the ECU re-learning the idle speed etc.
aukword1
yea well i do have to change my spark plugs but i doubt thats the problem, i will do what sentient said, i hope it works.,.
Sentientbydesign
96 I30 - Sold
I'm SentientByDesign...of course it will work... ...Oh sorry, forgot I wasn't in my own little dream land lol.
Based on your report of the higher Idle, I'm thinking your throttle is tweaked and needs to be slapped around a little like a used hooker
But! Since you have the reset as an option, you might want to try that first
Jacko3
joe603
Let us know what you find! ...did you ever take it to the dealer or autozone to get it scanned??
aukword1
ok i fixed it...i took off the negative terminal to the battery and let it sit for a few hours then bamm!...back to normal...my idle revs are normal and no check engine light...thanks guys!!!! now all i need to do is replace my camber arms in the rear!
