How many miles are on this vehicle? im around 92,000 on my 06 m35x, will be replacing the plugs VERY soon.rxmclaren7 wrote:so i dropped off my daughter and the CEL light came on....my car ran a little rough like it was missing a little....so i took it to my friends house and he checked the code and it said "cylinder 4 misfire" what the code # was idk...but he cleared the code and the car did not start....we jumped it and it started like nothing was wrong....drove it around the block and it started to miss again....although it did not throw a CEL light....i drove it home and i steped on the gas a little and the CEL light flashed but did not stay onplease oh please almighty NICO club HELP!!
Gotta be honest with you bro, $575 for spark plug replacement and an oil change seems really steep to me, but thats just me. anyway, im bumping this thread because id like to ask you, since you have the same car as me with over 50,000 miles more, and also live in new york where we have been getting some pretty intense weather lately.. have you developed any leaks of any kind? At the moment, im NOT getting ANY CEL. However, lately Ive noticed a very small intermittent leak of some kind of fluid in the driveway. its very slightly more to the passenger side. ive done a little research and have read some people mentioning a similar leak being linked to valve covers and there gaskets. i previously stated ive never had the plugs changed on my vehicle but am considering doing it next week. should i bring it in and see what they say about it? i guess im asking if you've had any problems with your valve covers or valve cover gaskets, or anything else for that matter lolrxmclaren7 wrote:well the prognosis is good...it was only a bad plug...i had the dealer replace all of the plugs just to be safe and they also did an oil change and cleaned the throttle body....all total with the diagnostic stuff $575...better than i was expecting....thanks to all who replied to this post....it truly helped a lot!!!!
I'm from Albany and have the same car. No leaks.cji4130 wrote:Gotta be honest with you bro, $575 for spark plug replacement and an oil change seems really steep to me, but thats just me. anyway, im bumping this thread because id like to ask you, since you have the same car as me with over 50,000 miles more, and also live in new york where we have been getting some pretty intense weather lately.. have you developed any leaks of any kind? At the moment, im NOT getting ANY CEL. However, lately Ive noticed a very small intermittent leak of some kind of fluid in the driveway. its very slightly more to the passenger side. ive done a little research and have read some people mentioning a similar leak being linked to valve covers and there gaskets. i previously stated ive never had the plugs changed on my vehicle but am considering doing it next week. should i bring it in and see what they say about it? i guess im asking if you've had any problems with your valve covers or valve cover gaskets, or anything else for that matter lolrxmclaren7 wrote:well the prognosis is good...it was only a bad plug...i had the dealer replace all of the plugs just to be safe and they also did an oil change and cleaned the throttle body....all total with the diagnostic stuff $575...better than i was expecting....thanks to all who replied to this post....it truly helped a lot!!!!
thanks
Hey rx,rxmclaren7 wrote:cji4130,
just as an update i had my oil changed again today and it looks like the valve cover gasket is leaking...i am going to bring it up to the dealership to see what they say...i will keep you posted!
thanks for your input steve. im glad you mentioned this, i personally changed my oil cooler o-ring seal at my last oil change(about 2700 miles ago). i also attempted to replace that spring loaded relief valve thing(i was unsuccessful at getting the old one out, but the spring, and bearing were still fully functional so after some frustration i gave up and continued with the oil change) im really looking to change my oil soon so i can get a look underneath the car and see whats leaking. i just wanted to mention i changed my oil cooler seal about 2700 miles ago and am doubtful thats whats leaking, at least in my case. thanks again guys, please keep us updated on this.SteveTheTech wrote:-I do not think these issues are related and would like to offer my opinion on this. I am in the DC area and do not have it nearly as bad as many of you folks way up yonder. I have seen a decent increase in small oil leaks with this unacceptably cold weather. M35s love to leak from the oil cooler seals. That is the metal thing the oil filter mounts too. The oil tends to run down the lower belly pan and drip from the holes under the sub frame and at the rear of the engine. Some oil seeping from a valve cover is not really much to be worried about. If the car smokes or you smell burning oil it is time to fix it. I always suggest cleaning it the first time and waiting to see how long it takes to leak again.
-If you are changing your own oil...you really should change the gasket every time. Most of the time they are good for two or three but should be replaced annually at least.
thanks for the info steve!!! my car runs and drives fine just has a slight odor of oil burning coming from the engine bay area! i will post a pic as soon as i can so you all can see what i am on about!!SteveTheTech wrote:Hey fellas,
I want to apologize up front for a lack of quoted responses, my time is short but I wanted to put my 0.02 in this thread.
-Kudos to the OP for doing something quick.![]()
-What is often overlooked when dealing with a single cylinder missfire P0301-P0306 (-P0308-M45) or a multi-cylinder miss fire P0300 (which are typically harder to fix) is if the Check Engine Light is on or flashing and there is an active cylinder miss-firing and you risk burning out your catalytic converter. This can happen very fast and may not be covered under warranty.
-Replacing the plugs probably means that they were not correct. A few days ago I had an 05 Q45 that would miss randomly and had terrible engine numbers. Turns out the the plugs were correct but on had a very small hairline crack. We replaced all of the just to fix it right the first time.Because honestly you are going to have to pay to have all of them removed to inspect, why not just replace them while your there?
-If a spark plug drops from more than 16" you should toss it, even if it looks fine. Often you can only see a crack after it has been arching with the spark plug tube.
Now I must preface this next part with I read this thread for the first time today...I did not see the oil leak twist coming at the end. Very interesting.
I'll continue when I get back.
Why would you ever do that?cji4130 wrote:i also attempted to replace that spring loaded relief valve thing(i was unsuccessful at getting the old one out, but the spring, and bearing were still fully functional so after some frustration i gave up
Because it says to replace it after every dis-assembly in the service manual?SteveTheTech wrote:Why would you ever do that?cji4130 wrote:i also attempted to replace that spring loaded relief valve thing(i was unsuccessful at getting the old one out, but the spring, and bearing were still fully functional so after some frustration i gave up
