turbocat »
https://forums.nicoclub.com/turbocat-u141870.html
Wed Sep 09, 2009 3:36 pm
when you get the code, does the obd II reader, say something like bank 1 sensor 1, bank one is the bank of cylinders with the number one piston, and sensor 1 would be the upstream o2 sensor, upstream meaning in front of the catlytic converter, not behind it, the heater inside the o2 sensor, heats up to 600 to 650 degrees, within 20 to 60 seconds, older cars don't have heater circuit inside the o2 sensor, if the heater circuit is failing, it can take your pcm, powertrain control module, longer to go into a closed loop mode. and if the engine is just idleing, the exhaust temp may not be enough to keep the o2 sensor above 600 degrees, and that could put the pcm into a open loop mode , i have read on the nico forum to use the factory nissan/infiniti o2 sensor, some after market o2 sensors may not be within factory specs, not for certain, but i think denso makes the o2 sensor for nissan/infiniti
