CEL but no code
Flipnirish
Car: 240 sx
Did a lot of searching and came up with nothing. I have a 96 240sx all stock no mods w/ KA24DE. The Check engine light is on and flickers. I've hooked up two different code readers to the obd II port. Both read no codes, but they show TPS is 100%, MAF at 73.02 which is wrong as well, and engine temp at 401 which is ridiculous. The car was at idle when I checked for engine readings. I checked for codes at ACC on.
I'm so stumped and don't know what else to check. Could this be a bad ECU?
Oh forgot, while at idle, car sits at 1553 then dips to 840ish then back.
TIA for any help,
Tommy
S-ICHISAN
Car: 89 240SX COUPE W SR20DET...
it seems like the ecu
u should hook up consult it helps better
Flipnirish
Car: 240 sx
I just did some reading about the "Consult." But shouldn't any obd II scanner work? And are dealerships the only place that have these? What a monopoly!
Flipnirish
Car: 240 sx
Found my problem! Went in for the ECU, uninstalled it and opened her up. Looky what I found, a s*** ton of bugs!
Installed another ecu and no more CEL!!
FIXED!
