Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Thu Dec 09, 2004 3:13 am
The ignition advance number [in 0.1 degree increments] is the SUM of a dozen parameters:
Coolant temperature, rpm, tps voltage, speed, gear selected, MAF flow rate, knock sensor accumulated knocks, time/rpm rise rate, time rate of throttle openingtps rate of change, battery voltage, AC on/off/, and ambient temperature.
Each parameter creates a + or - offset from a preprogrammed rpm and load value.
Having the perfect ignition advance at each rpm increment is critical to ride the fine line betwen knock and loss of potential power and efficiency.
1 more degree can allow knock to start , but it takes a 4-5 degree reduction to stop knocking once it has begun!
To create peak torque the ignition advance must be such that the bulk [~~~~66-70% +-] of the fuel has burned by 15-17 degrees after top dead center. So the combustion time varies from -40 +17=57 degrees at light cruise to -22 +17=37 degrees at WOT 4,000 rpm.............and -15 + 17=32 degrees at idle. A -15 to a -40 total advance [BTDC].
Factory settings are usually 3-5 degrees less than optimum advance.To protect against bad gasoline and computer slow response time in calculating a closer to ideal number. Bad sluggish sensors.
In 90-95 a separate WOT map [look up table] is provided for each gear to take some of the guess work out of calculating an ignition advance number!
Still many sensor modify the end result! 1st gear acceleration depends more on the MAP while 2nd has more time to think about what the correct number is.
750 rpms to 6500 rpms in less than 4.5 seconds in 1st vs. 7.5 seconds in 2nd gear. The computer makes a full cycle calculation every 1/10 of a second so 450 cycles [chance to change ignition advance] in 1st vs 750 cycles in 2nd gear.
Modern 96 and later calculate 10 times faster and 2002 are 20 times faster.8 bit vs 16 bit vs 2 -16 bit cpu. The computers are always behind guessing the correct value then applying a correction value based on knock counts per 1/10 of second.........part of adaptive learn system.
Without the feedback from KS they just give up and retard the number to what was safe when the engine was new.........whether that is fully safe on a old abused ngine is unknown [safe number plus 3 more for age?].
The is no parameter for ecu to know how many miles are on the engine.
The KS are really the ONLY feedback the ecu has, other than rate of change rpm............WOT switch vs gear vs rpm rise per second but you could be in mountains not on level road so -------pretty useless.
The KS are CRITICAL to safe engine operation.>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Just one of those $300-400 +500 = $900[plenum removal] repairs necessary every 100-200k........when you change plenum hoses you always replace BOTH KS plus harness [$400] to save on duplicative labor.Same with valve cover reseal and all hoses ..........what $1700 to keep things right for the next 100,000 miles compared to the $15,000 [15 cents per mile] in total maintenance and repairs per 100,000 miles......100k>200k.
Remember Honda Civics cost 6 cents per mile and older Q cost 15 cents just $7,000/6-7 years ~~$1,000 more per year plus fuel and incidentals.
People don't spend from day one over and above warranty repairs so by 100k they end up owing the car $5,000.............the 15 cents per mile assumes you have already spent the $5,000.Which is not usually true why we say every new to a used buyer needs to ASSUME the car needs significant work to bring back close to standard.
Buy a used Q do $5,000 in repairs then start spending the 15 cents per mile ........it gets worse if you don't drive 20,000 miles per year [spend $3,000 per year on M&R].........the M&R cost per mile........it always average $3,000 per year!
Used Lux cars cost about $8,000 per year to drive assuming payments/interest....... [about the same as a new Taurus]. Compared to $5-6,000 for new econo boxes/basic 4 cylinder manual pickup trucks or $10,000-$12,000 for brand new luxo cars [Q45/Ls400/BMW 540].
The guy with $250 payments, $250 M&R, $100 insurance, $200 gasoline,.......spends $800 per month to drive a used Q..............you can see that he skips M&R or significantly reduces it. Nothing left in budget! For repairs or maintenance!
Always think that a USED car can cost you just as much as the payments per month to keep running.
Money Smart people buy 2-3 year old econo box/pickups Japanese/Korean even domestics and save the $2-3,000 per year . Altima, Corolla, Honda.
Another example of my 2:1 posts.
You pay one way or the other......there is no free lunch in automotive ownership.
