kendem »
https://forums.nicoclub.com/kendem-u75303.html
Sat Aug 15, 2015 11:17 am
Thanks. About a year ago, I removed all the egr components, egr and bpt valves, egr tube, vacuum solonied, vacuum hoses, ect and tested/cleaned them.
However I did not remove the the egr block off plate (I think that's what it is called) and inspect further. I'm not sure where that allen plug is you are referring to? I am hoping to not have to remove the entire intake manifold to clean out the egr passage.
I do have the FSM so I will look again for that allen plug.
Thanks again.
