albert_ey »
https://forums.nicoclub.com/albert-ey-u73970.html
Fri Jul 25, 2008 11:51 am
Is this the 6-disc or single?
This sounds strangely familiar. My sister had a 2001 toyota camry, same thing happened to her. It would say, cd error, then just stay there.
I couldn't eject it. I turned the car off, let it sit for 10 minutes, then with the car off I pressed the eject button and there it was.
My dad also had the same problem, he has a 2003 Ford, with a 6-disc CD changer. Every so often, when cylcing through the cd's, it would get "stuck". It would make a ticking and buzzing sound. We would just have to wait until it worked.
One day I just took the radio out, opened that sucker up, and applied some lithium grease to the moving parts. We havn't had the problem since. I guess the grease that is put on there just dries up with the heat, that's why I put lithium based grease , it has a really high tolerance to heat.
I hope this helps
