CD player reads error
optonano
Car: 1997 Q45
The CD player on my 97Q displays read error, anyone has experience fixing similar problem? or where I can find info to repair it myself? The casset and FM/AM works fine.
do i really have to get a new stereo?
Thanks for any input.
Rex
Car: None
optonano wrote:The CD player on my 97Q displays read error, anyone has experience fixing similar problem? or where I can find info to repair it myself? The casset and FM/AM works fine.
You can try a reset by disconnecting the battery overnight, or a clean-er CD, but more than likely it's given up the ghost at this point .
Watch ebay for your cheapest/easiest replacement, pretty much any 97-01 (excluding non-standard DIN shaped Maximanuits) Nissan/Infiniti Bose CD head unit should swap right in. They usually go for about $125 give or take.
sdkhalsa
Car: 94 Q45 06 M35
Had the same problem on my 94' Q. As mentioned earlier, the problem is often a bad solenoid in the head unit which can be reset by removing and then reconnecting the battery cable. Not knowing this, I purchased a new CD deck from Joe which sits in a box unused. I would be happy to sell it to you at a good price. My solution, which I highly recommend, is to forget about the CD and put in an I-pod connector. There is lots of information on this site about doing this. It is a very cost effective way to go.
Rex
Car: None
sdkhalsa wrote:Had the same problem on my 94' Q. As mentioned earlier, the problem is often a bad solenoid in the head unit which can be reset by removing and then reconnecting the battery cable. Not knowing this, I purchased a new CD deck from Joe which sits in a box unused. I would be happy to sell it to you at a good price. My solution, which I highly recommend, is to forget about the CD and put in an I-pod connector. There is lots of information on this site about doing this. It is a very cost effective way to go.
What CD player to you have for sale (single in dash or changer)?
Yes, the iPod adapter is a good option and qsiguy was making ones that used Aux In on the stock Q Bose HU.
optonano
Car: 1997 Q45
Thanks for you guys advice! I will try to reset the battery and see how it works...definitely I am interested in getting a ipod adaptor soon.
how much would you ask for the cd player?
sdkhalsa
Car: 94 Q45 06 M35
I have the Sony 5 disc that goes in the trunk along with bracket. They no longer make the original 10 disc.
sdkhalsa
Car: 94 Q45 06 M35
I will let it go for $140. Original cost was about $225.
captainluigi
Car: 1996 q45t
i am interested in the changer. how much? is it plug & play with no mods into a 96Q?
thanx
sdkhalsa
Car: 94 Q45 06 M35
It is plug and play for 94' as far as I know. You will have to check on 96'
