Cd player problems on s13!!
Post all your Nissan electronics, car audio and stereo questions here!
hakosuka86
Car: Toyotas Nissans
I have a interesting problem with my radio on my s13,the cd player works and everything it turns on, i can adjust volume, change songs but no sound comes out, I swap a different one and IT worked!! but after a day i was changing song and the Sound went away Again.
I checked all the cables behind it 4 times and so did a friend can there be a possibility that my 240 its burning the cd players?
Im scared of spending 100$ on a new one thats gunna do the same thingor maybe i should just take it to a audio shop.
any ideas please reply thank you.
xckid
Car: 2004 Chevy Blazer ZR2
What kind of cd player do you have: brand and model
also have you installed new speakers or wires. If you have there might be one touching some metal and that will cause it to ground out, and it just kinda swings back and forth making contact every now and then. Or your speaker wires are just plain old and there not making good connection and still grounding out either way check your connections to all your speakers first.
hakosuka86
I believe your right!! because when i turn the car the radio goes on lol so must be a cable touching and doing the ground - out.
i will thanx.
