CD player not reading CDs
vang240sx
My stock 95 240sx cd player was reading CD's fine until the day I left the lights on and the battery died. Ever since then it doesn't read CD, burned or real. I searched the board but found no solution. The radio works fine and I can put a CD in and it seems like it tries to read it but after, it spits the CD back out, even a CD with no scratchs. Please tell me if you have any suggestions for making it read again. Thanks :)
slw240sx
Car: 1990 Ca18det 240sx Hatch
threatn it a couple times with a flat head screwdriver, then when it refuses your demands give it one last chance to redeem itself , then proceed to stab at it with said screwdriver an gut it good, then goto the store an by a nice aftermarket radio!
89sxRCR
Car: destroying self esteem
hmm. What cds are you trying to play? If its nsync or O town that might be the problem... otherwise id say its toast and its laser isnt reading... Pop it out and bring it to a repair shop or buy a new one.
topless@vabeach
Car: Electronics, anything that has trons in it.
This is going to sound stupid but it has worked on several cars brought in for repair. Remove your battery cable (+) and wait 90 seconds. Then hook it back up. Some radios need a Hard reset, that is where power is completly removed and then re-applied. If that doesnt work, go with the screwdriver suggestion.
MaineExport
Car: 95 Nissan 240SX FAL fans AEM intake Hot Shot header Apexi N1 dual Exhaust VLSD ABS NX 50 shot
The battery drain incident and CD player failure might just be coincidence. I've never heard of a loss of power JUST toasting the ability for the head to read a CD (maybe a power surge would do that.... but I can't see how).
Ayway, my stock Clarion CD player did the same thing. After about a year of owneship (I purchased it in January 2000) it just stopped reading most CDs. I would insert the CD..... it would make some spinning noises and other random sounds..... then spit it back at me!
Get a new CD player. It's not very expensive... and the sound quality will be much better. Two choices though: get a LOW power head and install it normally. Or, get a high power aplified head and bypass the facory amp.
