CD Player chatter
jimbomatic58
Car: 2011 Nissan Sentra S
Of late, my CD player has developed a sporadic chatter when the disc is spinning. Sometimes its loud, other times it disappears. Has anyone else had this problem? How did you fix it? Does this mean the player is near the end of its life? Should I get another player from a junk yard or put in an aftermarket one?
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
there are a bunch of used ones on eBay for cheap
https://www.ebay.com/sch/i.html?_from=R ... =0&_sop=15
amc49
Car: '11 Nissan Versa
'17 Nissan Altima
FYI............
http://www.370zcoupe.com/TSB/1TE5.PDF
ALL models, not just Z.
jimbomatic58
amc49 wrote:
Sat May 26, 2018 10:36 am
FYI............
I know how to handle and care for CD's. Mine are pristine. That is not the issue.
amc49
'17 Nissan Altima
Some handle them by the center hole and then common for fingerprint oil to make the disc slip. The magnet ring that clamps down on the center can be weak with use to slip too upon acceleration.
Depending on the construction, some drive makers plastic cover the very thin sheet metal disc guide parts with a thin layer of close tolerance plastic, being in a high temp climate can make the plastic begin to warp to crack off pieces and the ragged edges can then be struck by the spinning disc.
jimbomatic58
amc49 wrote:
Mon May 28, 2018 1:15 am
So are you telling me that you've had this issue in your Sentra and found that is what caused it?
amc49
'17 Nissan Altima
No. Problems in general I've found on players in other cars. If looking for exact causes then you open the unit up like I do. The center hole thing can happen to any CD or DVD player in the universe, meaning yours as well.
