hebcz00 »
https://forums.nicoclub.com/hebcz00-u244601.html
Mon Dec 08, 2014 4:01 pm
I just recently purchased a 2006 M45 from the original owner, my brother. Compared to my previous ride, a Honda CRV, this is a new world. My problem is the 6 CD changer, which my brother had told me did not work. I removed the unit (using this forum How To's) and removed the 3 stuck CD's. I have re-connected but it still is not working properly. It energizes, shows 6 disc icons on the navigation screen, however they are all "greyed out", none is highlighted as being active. The screen says "Please eject disc" then changes to "No Disc" when I press eject button as it makes ejection noise. The screen then returns to "Please eject disc". Load button does nothing but emit 3 quick "beeps". It will not allow loading or switching between discs, which are all "greyed out". So I purchased an identical recycled CD unit on ebay and installed. It does the exact same thing as my original. Makes me suspicious that it might be a wiring/harness/logic issue vs. the actual unit. Not sure if there might be a switch/contact that makes the CD unable to load except in park which perhaps could be malfunctioning? Anyone aware of that? Am I grasping at straws? Considering sending away my original CD to "Short Circuit Repair" but wanted advice as to whether this might be a lost cause, especially if the problem is not the unit, but some wiring issue. Thanks for any advice.
