jwm »
https://forums.nicoclub.com/jwm-u90623.html
Sat Apr 19, 2008 7:27 am
I have the same problem. The dealership failed to advise me this was a common problem and I would never have known that without this forum. The members are great. I have a g35 coupe with the nav system and the same problem, a/c system stuck with the controls not working and the radio is dead, even from the steering wheel. I checked the fuses and they appear fine. Is there a manual or instruction sheet that describes how to repair / replace it? How can I find the circuit board number to order? Also, I found a post about infiniti net but I could not find it anyway. The car has over 90K miles and I do not want to spend $900 to have the dealership correct the problem. Thank you in advance. I appreciate the input and help.
