CD Deckcausing Check Engine Light
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Condor1334
Car: 2009 Nissan Versa Hatchback
I was to busy to install the deck myself so I made the mistake of having Best Buy install it as i had errands to run at the mall anyways. Long story short is deck works fine, its a JVC deck but forgot the model right now, but I got a check engine light. Checked gas cap as I have had that issue before and its still there. Any suggestions to look for before i have them go back to the factory deck which was perfectly fine?
steed77
Car: 09 Versa Fresh Powder Sedan 6speed
Take it back to Best Buy, they should fix it. If not they should pay to have it fixed.
Condor1334
yeah thats what I'm doing. Didn't know if there was something unique with the Versa that i could point out to them to check.
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
You can fix it yourself.
Check this out...http://forums.nissanversa.org/zerothread?id=362669
Condor1334
mines the Service Engine Soon light, not the air bag light. It solid yellow as well not the red light of death. Bringing it to best buy to have them check it and finish/correct the install and have it set to go to the dealer tomorrow if need be if there's not other solutions
srellim234
Car: 2007 Nissan Versa SL hatch w/CVT
(sold 08/2011)
2008 Toyota Prius
(purchased 04/2016)
I was thinking you should approach it the other way around.
Take it to the dealer and have them check whatever code it is throwing to verify that the audio deck install IS the problem. By coincidence, you might actually have an engine problem that occurred at the same time as the install. The dealer should check the code for free under warranty.
Once you have the verified code, take the dealer printout to Best Buy and force them to fix it if Best Buy indeed screwed your car up.
Condor1334
If it is wiring does it void my warranty do you know by chance?? also best by said they could do it today and Nissan couldn't look at it until tomorrow. I figure if Best Buy puts the factory deck in and lights goes off we found the issue. then again could be completely wrong
Return to “Versa Technical Discussions”
