Kiven422 wrote:Its a Sony brand 10disc CD changer that sits on the side of the trunk... I'll give you the model number as soon as I have a chance to look at it.
The remote control is also connected to the sony changer
On the '94 Q45t, a trunk mounted Sony 10 disc CD changer was standard.Mine did NOT have a remote, and played through the CD button on the factory radio. I don't think ANY factory 10 disc Sony CD changers had a remote.
The Sony 10 disc changer factory installed by Infiniti was known to be short lived, usually around 2 years was all one could get from them. They could NOT be repaired in the field, even by Sony warranty stations. They had to be sent back to Sony, who didn't actually repair them, they replaced them. It was expensive. That's why a lot of owners replaced the original CD changer with an aftermarket one. I suspect that may be the case in your '94 "t" model. I had to replace mine 3 times, once under warranty, twice at $275 each. Last time I did it, the Sony warranty shop told me that Sony was almost out of replacement units and they would soon be discontinued and NLA. Not sure if that actually happened though.
As for wiring your CD changer to work with the CD button on the radio, I suspect it may be possible, depending on whether your CD changer output is compatible with the Bose radio, which it may not be. One of the audio guys here should be able to advise you on that.
