mrk442 »
https://forums.nicoclub.com/mrk442-u41471.html
Mon Mar 31, 2008 12:29 pm
I have a 93 Vert that i toasted the motor in.
I bought a supposedly strong running under 100k motor.. well it had a blown head gasket and pressurized my cooling system to the point of blasting out the overflow the first time i turned it over.. I pulled the head and used my strait edge to check the block and head.. both within specs.. So i slapped on a new head gasket and tried to start it up.. no start.. I check the compression and they are all sitting around 50psi.....
Its possible the head was warped more then I thought but i checked length wise.. width wise. cross wise and every other way i could think of and besides even a warped head should seal for a little while right?
so i am left to wonder whats my problem..
valves leaking? how can i check the valve seats i have heard you can pore acetone in the valves and check for leaks but i thought that was with the head off? any way to check with the head on since i don't want to buy new head bolts?
is it possible i got the cams back on a little wrong and they are staying open into the compression stroke?how would i check this?
anything else?
little help would be great before i pull the damn egnine again and find anouther.....
