mdmellott »
https://forums.nicoclub.com/mdmellott-u292054.html
Thu Oct 17, 2019 9:31 pm
Yep! That'll do it. The mechanic is spot on. To simulate normal ride height, after installation but before tightening the bolts, the wheels do need to be on the ground or the axle can be raised with a floor jack to get the same effect. Wheels on the ground is a sure bet to get it right but may be a bit awkward getting to some of the bolts with a torque wrench. If it is too awkward, you can always just make the bolts good and tight with a normal wrench so nothing moves, then you can jack it up as before and torque them to the proper spec.
