My '90 Q began running rough several weeks ago. Missing cylinder, and it was intermittent. Happened rarely at first, but progressively got more and more frequent. Apparently the missing wasn't affected by the engine temp...sometimes it would miss cold, sometimes hot, and recently it was missing all the timeI figured it was a bad coil based on the symptoms. I got some used ones this past week and tore into the car today. The #2 and #4 plugs looked horrible!
http://home.socal.rr.com/robverna/DSC01 ... C01239.jpg
These plugs are almost brand new! They were installed on 2/21/03, and have less than 1000 miles on them. The other six plugs looked fine. The #2 coil contact looked a bit rusted too. The #4 coil boot looked OK. The plug ports did have moisture in them, but I thought that was normal. All the other ports have moisture too.
Could this have been caused by some wierd arcing from a bad coil? That black stripe down the #2 plug isn't oil...looks like carbon deposits and it doesn't wipe off easily. I pulled out the old plugs that I removed in February, and all 4 from this head look fine. Nothing at all like these 2. I'm not all that up on corrosion priciples, but I'm hoping that swapping the coils will fix my problem. I ordered new wire harnesses for both heads when the problem first appeared, and they will be swapped when they arrive. Any thoughts? Anyone seen anything like this before? Thanks a bunch for your insights!
