Catch Can - S14 SR Does Not Have a Factory Catch Can
Thoughtful_One
Car: 1998 Nissan 240SX SE
2000 Honda Insight
I'm looking into a catch can setup and I can't seem to find the right setup in term of it being vented or recirculated.
I've noticed that during hard runs or taking corners hard, I can smell oil being burned off. Although, I had a leakdown test done a few months back and I passed with flying colors (>8% leakage, which is really good).
Unlike the S13 SR, the S14 does not have a factory catch can. The hose goes directly to a port located on the turbo inlet.
What is the best way to set this up?
Is it as simple as:
Old:
Proposed Setup:
Thanks.
Thoughtful_One
2000 Honda Insight
No one?
Geno750
That will work, and if I remember correctly, there is a port on the back right of the block where you could even drain the catch can back into the motor if you wanted to.
