onecrazyfoo4u »
https://forums.nicoclub.com/onecrazyfoo4u-u42462.html
Tue May 15, 2007 7:01 am
I searched, but can't find anything relevant to my questions. Right now I have a greddy catch can with small 10mm fittings, which is way to small to fit onto the redtop motor from what I can see. I'll probably sell that and get a new one. What size fittings do I need to order to fit the stock 5/8" hose that goes from the pcv to the intake? I can get an intake made with any size fitting I want, and they say the stock size is 3/4" nipple, which doesn't match up! Let me know what size I should be running, to fit in there properly.
Also, anybody have pictures of them hooked up? I want to see where you mounted them and what not. I know the can itself should be lower then the pcv to let the oil run downhill. Just show me some pictures and let me know what size hose/fittings you used! Thanks alot.
