Catback exhaust
silvia tunner
Car: 1995 Ruby Pearl s14
Im thinking about geting a Catback Exhaust but want to get the best opinion on which one would work best for me. Im looking to go with a 3". My KA is pretty much stock but will be getting turbo in a couple of months.
http://www.cardomain.com/memberpage/521442
bcuz
you dont wanna put a 3" exhuast on a stock car. I suggest you wait til you get the turbo and actually need the exhuast. Its not gonna do you much good, if it does any good right now.
silvia tunner
will i lose a lot of low end power? Because i've heard i'll gain a lot of high end power
SeVa-S13
Car: '05 GTO 6spd
Well, everyone else in the world has said that you will be sacrificing some low end, especially with 3". I went from stock to 2.5 and I did notice a bit less torque, but nicer mid-range and top-end. Three inches is indeed overkill on NA street driving but if you're going turbo soon, go ahead and get it so you can save yourself from having to buy two separate exhausts. ;)
raging panda
Car: s13 coupe
http://northwestnissans.com/bo...15327
Fresh Alloy forums are down (Gee, what else is new?) but when theyre back up, check out the links on the first post of this page. It shows little to no loss of low-mid power and gains of 12.2 hp. Everyone else in the world was going on what they assumed to be true and didn't have any dynos to back it up, im not blaming them, but here is a dyno sheet saying otherwise.
180fan
Car: 89 fastback
That's Alex's (of 5zigen-USA) install of the pro-racer exhaust I've got on my car. That's a 70mm, not a 80mm pipe. It's the one with the iconel burnt tip all stainless exhaust. Reason I know that is because that's the same chart Alex showed me when I was deciding on buying the proracer.
silvia tunner
which company should i go with? i've heard good stuff about zigen and apex
TurboKA37
"I personally have the turbo version (80mm piping) in anticipation of "future project(s)", and because I didn't want to go deaf I installed an inner silencer (even though it does not come with one)."
TurboKA37
silvia tunner wrote:which company should i go with? i've heard good stuff about zigen and apex
both are good exhaust manufactuers. look at the different exhausts they make and choose a version that fits your style and price range. i am personally going with a 80mm exhaust mostly because i will be going turbo soon and because this test proves that using a large turbo sized exhaust will not always make you loose low end torque but its up to you what size you want
silvia tunner
i want the exhaust to stick up and to the side a little
180fan
Car: 89 fastback
Personally I'd say go with the 5zigen. Just because it's all stainless (won't rust). The 70mm is a good balance for either turbo or not. It does however come out pretty straight back so that might not be the look you're looking for. N1 is a common exhaust for the s13's and s14's just because they're a street proven exhaust. The proracer is more expensive but I think it's got a better build than the N1 regardless of the 70mm piping. Just for thoughts, the Kei Office's exhaust for the s14 is 70mm.
Spec-R
what about a 3' exhuast with a test pipe???? will i loose low end there?
180fan
Car: 89 fastback
Dunno, never did that personally. I hear alot of people say that they lose some low end with a test pipe. If you're in a region where the cops would check for a catalytic converter, I'd probably just keep it on. Here in CA the fine is $1,400 according to my buddy when his wrx got pulled over and the cop wrote him up for not having a cat. Another thing to consider, is this: If you put a test pipe on, it's just a matter of time before the air in your area will get polluted (chances are you're not the only one with a test pipe) and the emissions policies will change to try to correct that. Also it's just better for mother nature. So that's your call from there.
silvia tunner
which type of exhaust comes with 70mm and that it sticks up and to the side?
TurboKA37
hold on let me go look for you
Bunta240
You might also want to check out BRM. They pride themselves in as non ricey as possible exhausts.
Drill_Sergeant
HKS HKS HKS
dr!ft
Car: 1988 Isuzu Trooper II, wish it was a 240...
My personal fav is the 5-Zigen Border III 70mm exhuast. And no gigantic tip either (though you might prefer one). Either that or the Blitz Realize TT. It's 76.5mm making a nice compromise between 70 and 80mm. http://www.store.yahoo.com/pha....html
EazyBreazy
where did you find the info on the kei office exaust. i looked for hours for that thing. where can i find it is there anyone that distributes them here
ps sorry for the thread jack....
The Mic
Car: 3Z Wmb
hey would the HKS Sports catback for S13 240SX work well with the sr20det? and what are the disadvantages and advantages of it.
more info : http://w1.igateway.com/clients...=form
typex240
Car: drive around
This might help you pick what you want....I personally have Apexi N-1 Dual, and it is very nice and satisfies me in every way. I pick this one because of look and performance, especially sound of it. Some of fancy exhaust performs as good as this model but they sounds like one of those cheap muffler on Civics. Also, this one is made for 240sx and rx-7 only. Best part is ground clearance is way better compare to other models especially ur ride gotten lowered.
Here some infos.....Good luck!!http://www.zilvia.net/reviews/...at=28Sound of some exhaust....I think N-1 dual sounds best out of these...http://www.zilvia.net/faqs/faqs.asp
240marcuSX
Car: E34 525i
E46 M3
Im working on a KAT right now, and i went ahead and bought the Greddy/trust Evo II exhaust ($$) but i got it for a deal that i couldnt pass up. I put it on a while back, and it was tremendously loud. so i took it off for the time being until i can get a silencer..
nicer top end, a bit worse low end.
silvia tunner
Even tho i still won't be getting my Turbo for a few months should i still get the 3" Catback ? I think im either gona get the Apexi N1 or the HKS Hyper. both have the style im looking for (Exhaust stands up and tilts to the side a little) what do u guys think about the 2?
