themadscientist wrote:I am researching weak points and consulting knowledgable guys on this end. I hear rods go on high-revvers and forgies for anything over 400hp. I can understand the rod thing, I think it's the bolts myself, they are small, they probably stretch and induce the bearing wear and rod knock. All this time I was damming the oiling but I am starting to think it's rod bolt stretch that's doing it. I have to price out aftermarket rods and pistons and figure out what I can afford. I may end up using OEM again with new bolts.
I´m also researching and can only come up with one answer, oil temp.
All the CA´s I´ve rebuilt are German imports, all Autobahn driven for years, all stock and all without regular oil changes.
The next proof is the oil cooler thing, I´ve mounted coolers on a few cars with untouched engines and good service history.These cars have been tuned and then used for drifting, track racing and drag racing. High revs and general beating, never any problem after the cooler.
If the bolts were weak they would stretch at high boost, high revs and other abuse, never happened to me.We use stock bolts in 400 hp CA´s and no stretching.
Hmm... Hard one but I´m pretty sure it´s about the oil. Boiling oil.The cooler will lower the temp and make it possible to add some oil.More oil and cooler oil is good in a car with a closed front end like the S13.
