NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Thu Jun 03, 2004 6:17 pm
best way to check cat efficency is on a 5 gas analyzer(smog machine) There are three ways of doing it but the best way is with an intrusive test inthe exhuast. You first take a reading at the tail pipe at a predetermined RPM {and speed if on a dyno} after you log your CO,HC,and NOx readings. then you shut it down quickly drill a small hole in the exhuast pipe right in front of the cat,change the probe on the analyzer to the intrusive probe,stick it in the hole and bring the car back to the predetermined RPM/Speed let it stabalize and record your numbers again. You take those numbers and compare them. The Cat(s) should reduce your readings substantially from what is going in to it. There are minimum numbers that apply here but it would just be confusing as it depends on how efficent the combustion process is. If you have a clean burning engine the cat(s) dont have much work to do. So numbers could be well below what the cat should and can do worst case. You just really want to see a significant drop in the numbers whats going in to the cat to whats coming out of the cat.
