Catalytic Converter
tpettis0505
hello, I would like to know if anyone has replace their Catalytic Converter on the M56? If so, was it an aftermarket Cat or Dealer? I was told that the cat on the driver side of my vehicle was going bad so I will need to replace it. Just looking for information from people who has experience this issue. Thanks,
Ilya
Which one? The lower or upper? As far as I know, the upper requires engine removal, etc.
armybrat
Car: 2012 M56x with Tech Package (sold)
Custom 2-1/2" X-pipe exhaust with OEM sport mufflers
HPS intake hoses
Uprev tune
tpettis0505 wrote:
Tue Jan 23, 2018 1:42 pm
I personally haven't had to replace mine. The primary cats are integrated into the exhaust manifolds. You have to replace the whole manifold. Unfortunately, the driver's side requires pulling the motor to replace it. Around $2K dealer price. The passenger side can be changed with the motor in place. With that said, I would take the front Y-pipe loose and inspect the inside if possible. Also check A/F sensors and O2 sensors. You may be able to clean them and recheck codes.
walt1227
Car: 2011 Infiniti M56S
For the price you would be better off having some custom headers made if it is the main cats and not secondary cats. Think Kooks would make some for us around $3k.
armybrat
HPS intake hoses
Uprev tune
walt1227 wrote:
Thu Jan 25, 2018 11:01 am
Headers would be really nice, but you would still need aftermarket cats installed to pass emissions. (if you live in a state that requires it) The ports for the A/F and O2 sensors would also have to be welded in...then the installation. That would bump the price up even more. For a daily driver, especially with a stock tune, I believe I would just replace the manifold. I would also look into why the cat went bad. As a general rule, they can last the lifetime of the car. What kind of gas is the OP using? Driving habits? Using fuel additives? Following proper maintenance? Just a thought.
tpettis0505
Ilya wrote:
Tue Jan 23, 2018 2:55 pm
It's the Upper Cat.
Ilya
Yeah, that's gonna be a PITA to do...stupid design by Infiniti. Probably to force people to go to the dealer for this work and getting $$$$ from customers.
Kboakye87
Car: 2011 Infiniti M37x
Is this covered by Elite Warranty?
EdBwoy
Kboakye87 wrote:
Wed Feb 14, 2018 9:16 am
I am not sure about the elite warranty, but there is a federal warranty that could cover the OP depending on mileage, date of purchase etc.
Here's a link to another other thread whose solution we'll never get to know:
post6720244.html
Brandengonzo
Car: Do not own a Nissan. But I have Nissan dealership training and currently work at a Japanese auto repair specialty shop.
Hey guys, I saw this thread when I was looking for information about changing the cat.
I work at a japanese repair specialty shop and we have a 2011 m56 with the bank 1 cat that has gone bad. All data, identifix, and pro demand had no information about the procedure to remove the exhaust manifold/cat for bank 1. So I winged it. Unbolted the y pipe, unbolted the support plate for the steering rack, removed the column from the steering rack via the slip yoke that bolts onto the steering rack, hung the steering rack with a bungee cord, unbolted the sway bar at the sway bar bushing and let it hang by the links, supported the engine from the top on the drivers side head ground bolt, remove the drivers side motor mount, then I just slipped the manifold out the space between the subframe, and the firewall.
So no need to remove the engine. The whole process took 4 hours including replacing the upstream and downstream 02 sensor
Ilya
Brandengonzo wrote:
Sun Dec 15, 2019 2:23 pm
Branden, thank you for this post. Any chance you have some pictures? That would be a GREAT help to the community.
Brandengonzo
Yea for sure I can take pictures tomorrow at work. The vehicle is still there for other services so i will just draw arrows to the parts I was speaking of since i already finished the job
EdBwoy
Thanks for sharing that info. I have done the same for an 06 M45, raising the engine by jacking the oil pan, because I didn't have a way to hold it from the top.
Do you recall seeing anything visibly wrong with the catalytic converter when you removed it?
I've been trying to acquire a bad catalytic converter for a long time.
Ilya
Brandengonzo wrote:
Sun Dec 15, 2019 4:42 pm
You da man, man.
Also, if you have the bad cats and can share, as Ed says, lets do it so we can try to get some visibility into this issue as it's starting to affect more and more V8's as they hit certain mileages.
Yoda's Master
Car: 2012 M56
2009 370z
We want headers and down pipes :biggrin:
rjoe
Car: 2011 M56S
About to take on this project. Dealer gave me a $2,500 quote to replace the passenger cat, header, upstream o2, and gaskets. They replaced the driver's side under warranty about 2 years ago, very glad that was at least covered under warranty.
Any pics would be helpful Brandengonzo
Mjkkb2
Car: 2018 Infiniti QX60 AWD
2011 Infiniti M37S
2011 Nissan Quest
2001 Infiniti I30t(sold)
It should.
rjoe
Car: 2011 M56S
Mjkkb2 wrote:
Thu Dec 19, 2019 1:27 pm
It should.
They did my driver’s side under Elite warranty @ no cost.
