slybydesignq45t »
https://forums.nicoclub.com/slybydesignq45t-u98436.html
Wed Dec 17, 2008 8:30 am
Q45tech, I think you hit it on the nose. I researched symptoms of a failing or failed cat. When my car was on the lift everything was bolted down good, bushings looked good, hoses looked good and tight. So I could not not figure out what that metal ball tin can noise was. I did some research and found that the noise could be from a bad cat. It only happens when idling, or going in reverse. I don't think my cats are totally shot or not I wouldn't be able to drive if they where fully clogged.
As far as me saying a little more then usual exhaust threw my pipes, when I first purchased my car I had 0 visible exhaust out my pipe. Once it got cold I can see the exhaust, which most say is normal, but I assumed it should go away after car warms up with that said, I also notice it comes out slightly thicker then other cars, not so much to make me worried, but enough to make me notice it. The mechanic looked at it and said it still must be cleaning itself out from the throttle body cleaning I did a month ago or so.
This is about the same time the tin can rattle sound became more prominent. That was one of the reasons I had the throttle body cleaned. I have tried passing smog twice and both times I failed do to two different reasons two different times. This time it was my NOX reading. After working with some mechanics we all agree its going to be the EGR witch did fail a pressure test and or one or both my cats. If I replace one, I might as well do both and the O2 sensors. Plus even if it is just one of my cats about to fail I hate that rattling noise and its kinda embarrassing driving a nice car and on idle that rattle noise makes people look at you.
