lightsout »
https://forums.nicoclub.com/lightsout-u71638.html
Wed Feb 18, 2009 2:33 am
before you dump your converter, make sure that the ground wire from your converter is still connected to the body. My ground wire got ripped off somehow and caused a CEL code...i replaced the ground wire and disconnected the battery, and presto= ran better and smelled better too.
it would be the Cat just below the center console of the car, after the flexible Mesh at the end of the y-pipe.
if your knock sensor is back, your engine would be clunking when reving or accelerating...does it do that?
also, there is an O2 sensor after your Cat, if that sensor goes bad it will usually cause your computer to throw out the Cat as the problem when really its the 02 Sensor, keep that in mind.
Modified by lightsout at 1:35 AM 2/21/2009
