catalytic converter mounting bracket
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
crankor
Car: 2011 Infiniti FX35
I keep forgetting to ask, what kind of hardware goes on the end of the mounting bracket for the cats? Mine was rusted off and I got a replacement but I have mo idea if theres suppose to be bushings in between the mounts on the cat ends. I have the circular ones for the frame
If it has the flat tab with oval hole, then nope. Bolt it up, the one that mounts to the frame should have some cushioning device.
crankor
they dont even line up with the replacement cats. 😑Maybe I'll just use some carribeaners ha
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
