JNM240 »
https://forums.nicoclub.com/jnm240-u395.html
Wed Nov 06, 2002 8:02 am
Topping off your gas wont do jack s***. You have a fuel injected engine, meaning the car's ECU is telling the fuel injectors exactly how much gas to put into the mix at each and every RPM and temperature. I think the only way to superheat a cat would be to run extremely lean, which is worse for your engine than your cat. You could easily foul up at cat if one or more of your sensors are out and you are running super duper rich (been there, done that). If you are smelling something only when the tank is full, check your gas cap. They do get old and lose their seals too.
As for your idle issue, i am assuming you do not have your A/C on, because, if so, when the compressor kicks on, it will bring the idle up to 1000 RPMs. I hope thats all it is, if its not, let me know.
