chucklee2000 wrote:I have the same issue, trouble code P0420. I read on another forum that the pre catalytic converter needed to be replaced. I am trying to confirm that this is correct and that the right engine bank, or bank 1, is toward the front of the car. I don't want to replace the wrong pre cat.Did you ever get a satisfactory answer or have the work done? I have emissions testing looming as well and want to do it right the first time.I am also interested in knowing if this can be done by a DIY machanic with regular tools.
You still have the 3.0 in yours if I remember correctly. If so, it's more than likely the front tube assembly and not the pre-cat.
