nayshean wrote:before i begin i want to let you know i have searched all the threads.
my problem is that my cat converter on the driver side of my '94 q45 ticks and rattles, but when i use the redline fuel system cleaner the noise stops.what is the initial cause of the cat converter knoise.
Probably means your cat has failed (internal components) and now needs to be changed. Fuel must be rough in your area? Bang on it with your hand and you'll probably hear it rattle. If one goes you might as well change both. It's common for these things to be the first thing cut out of the car when it arrives to a junkyard so tough finding used.
..Drew...
