1991S13 »
https://forums.nicoclub.com/1991s13-u22320.html
Fri Aug 19, 2005 7:32 pm
You do not gain massive amounts of power from removing your converter. Even if you don't need one, I still would run atleast a high-flow. Don't mean to get all EPA on you, but just because you don't need one doesn't mean you can go blowin' your gases all over the place, lol.
Removing it will reduce backpressure, which is always a good thing. You may pick up like 1 hp maybe? Not anything you will notice though. Might make more sense if you are turbo'd and there is a lot more air coming through, but taking it off a mostly stock car isn't going to make a difference. Not putting one back on will save you about $100 if you need to replace it though. Get rid of the resonator. That chokes it up more than the converter.
Im tired...sorry if Im rambling.
